Errors validating topology - "Must Not Intersect Or Touch Interior"
3276
08-27-2012 08:19 AM
Zeke
Honored Contributor
I have two polygon layers, parcels and subdivisions, but only working on parcels now. I'm running into what I think is a problem validating topology prior to loading it into a parcel fabric. This is my second set of test data; I was able to get the first set into a parcel fabric with help from a number of folks here (thanks again!).
First I validated the parcel polygon layer against itself using the rules Must Not Overlap and Must Not Have Gaps. Then I created lines from the parcel polgons using Features To Lines. Okay so far. Then I added the six rule topology described in step six, page 12 of the white paper "Loading Data into a Parcel Fabric". Everything checked out except the fifth rule - "[Line feature class] Must Not Intersect Or Touch Interior". Every parcel line that shares a boundary with another parcel shows up as an error - 1067 of them (see attached).
This can't be right. I don't recall this error with my first set of data, but maybe I did something differently this time. Don't know what, though. Any ideas on what's going on? Thanks.
Zeke
Honored Contributor
Please disregard. Posted in General Questions forum, unable to delete or edit here.
