Error importing LGIM schema with X-Ray to SQL Server
3169
12-31-2013 08:33 AM
PatrickKowta
I'm trying to load the LGIM v10.2 schema into a new SQL Server database using the X-Ray Add-in.  I have followed the published instructions, but get the following message when I hit the Import button:
XML Import Error:Database user name and current user schema do not match.
[LGIM.GIS.AED_ATTACH]
I have created a schema with the same name as a SQL User account.  The geodatabase specified in X-Ray uses a connection for the same user.
Does anyone have any ideas?
Thanks and Happy New Year!
Pat
ArcCatalog 10.2
Windows 7
SQL Server 2008 R2
Windows Server 2008 R2
ScottOppmann
Have you tried importing the schema in to a file geodatabase and then copying the features to your SQL Server DB?
