Construct from parent - island parcel/subdivision
2698
12-04-2013 07:24 AM
JeffWard
Honored Contributor
I am trying to get a process together for entering our parcels into the parcel fabric and the local government information model.  Is it advisable to start with a parcel representing an entire PLSS section and then use construct from parent? Or is it better to start with one of the individual parcels and build out from there?
I have been experimenting with the construct from parent method and I run into a problem when I am entering a subdivision that is an island within the full section.  I enter the connection lines to the point of beginning and then enter the standard boundary lines for the subdivision, but when I build and mark the parent as historic, the connection lines to the point of beginning are duplicated in the two remaining parcels.
Or do I create a new parcel in a plan, then once that one is created and joined, create a remainder parcel of the full section?
I wanted to be able to use the basis of bearing option, but it is only available in the Construct From Parent?
Any advice would be appreciated.
Jeff Ward
Summit County, Utah
