Community Planner Template Configuration
918
04-25-2014 09:52 AM
by Anonymous User
Not applicable
I am configuring the Community Planner template and having difficulties getting the layers to show up after the plan has been submitted. I configured the downloaded application, and after completing the instructions opend it with ArcGIS Viewer which needed to "upgrade" the applicatin. Upon configuring some of my other layers I wanted included as operational layers, I noticed that after entering a couple test plans not all the layers would show up. For example after creating a test plan with Open Space, Mixed Use, Low Density ... etc I reopened the plan and only  Open Space polygons show up. I looked at the operational settings and they all looked the same. I moved the Open Space down the list and Previewed the application and Open space was now not showing up but nor was any other portion of the plan. I shufffled around some of th layers and put them in rest service order 0 - 7 and three layers showed up but not others.  Open Space is (7) and when moved to the bottom is does not show up .
Any thoughts ?
by Anonymous User
Not applicable
Nevermind.... a recheck of the config rest services saw a small typo that was used when Find/Replace was done.
