Attribute Assistant - NEAREST_FEATURE_ATTRIBUTES - Empty Geometry
7189
14
03-12-2014 06:04 AM
KennyWebster
Just upgraded from 10.0 to 10.2.
Worked fine in 10.0.  Just pulling 2 attributes from a street feature class (from sde) and loading them into a civic point feature class (also sde).  For whatever reason it's now giving an error saying cannot be performed on empty geometry.  Clearly the geometry is not empty.
Any clues?
DominickCisson
Looking at my PC, I have the C:\Users\%username%\AppData\Local\ESRI\Desktop10.3 folder, but no AssemblyCache folder therein. I’ll keep searching elsewhere for it. Any suggestions?
Dominick A. Cisson, GISP
GIS Administrator
Phone: (303) 795-4472
Arapahoe County’s GIS on the Web: http://gis.arapahoegov.com
Try not to become a man of success but rather to become a man of value… Albert Einstein
MikeMillerGIS
Esri Frequent Contributor
It is hidden by default, you need to show hidden files.  If you paste this into your file explorer it should take you there
C:\Users\%username%\AppData\Local\ESRI\Desktop10.3\AssemblyCache
DominickCisson
I’m showing hidden folders, and there’s still nothing there. Regardless, I uninstalled it from ArcMap itself. What is the best source to get the Attribute Editor? It seems to be included with a dozen different ESRI projects out there. I just want to make sure I’m getting the latest version.
GIS Administrator
MikeMillerGIS
You can find detailed help here and a list of locations to get it.  They all include the same version of the tools.
Attribute Assistant | ArcGIS Solutions
RobertBorchert
Honored Contributor
Are you in a geometric network?  If so have you tried deleting the GMN and rebuilding it?
be advised if you do and your in SDE you should compress/compact it several time first.
