Attribute Assistant - JUNCTION_ROTATION Expression
1414
02-20-2014 12:31 PM
Corbinde_Bruin
Hello all,
I am completely new to using Attribute Assistant. I have been searching for help for some time on how to use Attribute Assistant to its full potential.
My goal is to plunk down a point feature and immediately have it rotate square to the nearest line feature. I haven't managed to do anything like this yet. Can someone point to some documentation or examples that have more complicated actions than just rotating based off of a field?
Thank you,
Corbin de Bruin
MikeMillerGIS
Esri Frequent Contributor
Corbin,
   The Utility Network Editing configuration uses this rule heavily.  The point must intersect the line.
MichaelVolz
Esteemed Contributor
Can the Attribute Assistant be setup in either a SDE geodatabase or a file geodatabase?
