Attribute Assistant Intersecting Raster Method Not Working
2723
10
01-06-2014 11:49 AM
GregEpp
The Attribute Assistant tool has been an extremely valuable tool but I have not been able to get the 'Intersecting Raster' method to work on our enterprise SQL database.  I am using version 2 of the attribute assistant. The following syntax worked on a file gdb but not on SDE:
Table Name: RMoN_San_Access_Chambers
Field Name: RIM_ELEVATION
Value Method: INTERSECTING_RASTER
Value Info: DEM_5M_2002|Pixel value
Does anyone know why this works in a file gdb but not on SDE?
Thanks.
MikeMillerGIS
Esri Frequent Contributor
Oh, then I bet it already fixed.  We made a lot of those fixes at 10.1.  We will not be updating 10.0.  We are finalizing our 10.1 Quality Improvement Patch testing and should have it out shortly.
