Attribute Assistant: From_Junction_Field
3491
09-05-2014 09:21 PM
Fuad_HasanOvi
Hi Everyone,
Greetings. I am new in using Attribute Assistant and having some difficulties. I have a line shapefile with geometric network. The line shapefile have two attribute field: "StartNode" and "EndNode". Each and every geometric network points file have an unique value. I want to add the unique value of the point file into the start and end of the line shapefiles. I wanted to use "From_Junction_Field" method of Attribute Assistant. My DynamicValue table is like the following:
Can anyone help me with this issue? I will be very grateful. Thanks in advance
Fuad Hasan Ovi
