Attribute Assistant and Versioning
8723
12
05-21-2012 06:00 AM
deleted-user-sxViYNIAAUFF
Is there an issue with the attribute assistant and versioning?
It appears that the attribuite assistant only works when I do not edit a version.
I must be directly editing the SDE tables.
JustinConnerWR
This is supported as of November 2012 per Configure GenerateID table - Attribute Assistant | ArcGIS Solutions
MikeMillerGIS
Esri Frequent Contributor
This rule always grabs the last ID and increments it by 1.  What you are trying to do is not supported.
JustinStangl
OK that makes sense, thanks for help!
