Attribute assistant 10.1 - Problem
1353
02-27-2013 01:13 AM
CésarPires
I have a problem with de attribute assistant.
The button to Run Geo Change Rules doesn't work, instead it runs the attribute change rules.
Another problem is when i run the Create Rules button it works fine but afterwards it continues to apply the same rules in all other buttons.
I tryed everything to resolve the problem without success.
I have windows 7 64 bits and ArcGIS Standart 10.1 sp1
MikeMillerGIS
Esri Frequent Contributor
Have you logged a tech support call?  Are you using the most recent version from the resource center?
CésarPires
No i didn't log a tech support call. I'm using version 10.1.1.1 of Attribute Assistant.
