Address points not on actual structure , but are on end of driveway
14375
20
04-22-2019 01:47 PM
NikkiHill
There is an app my County elections office hosted on ArcGIS Online. This app and the assessor’s office app have one fatal flaw, the address points created by the County 911 are placed at the end of the driveways. When using this address point layer as the search layer which is the most comprehensive layer database my county has, creates the problem because boundaries for jurisdictions usually follows the parcel lines. And if the address point is outside of the parcel at the end of the driveway the return district/precinct/levee can be wrong.
One major undertaking between myself, the County 911 will be coming up with a way to get one addressing layer with all address points on the structure. That way when I go to create an application, the district, levee, or area I am looking for would be accurately represented when I put in an address.
I am not experienced in scripts, let alone know where to even enter it in ArcPro. Is there a way to do this less painfully than moving my 35000+ address points to be located on top of the structure instead of at the end of the driveways?
John_RMellor__GISP
I would be cautious.  The bulk of your join should be fine, but I have experienced where there are multiple structures on a single parcel and sometimes they share an address and sometimes they are separate addresses.  It sounds to me like your join may only take one structure into account.  If a home were to have an unattached garage, would your join be a one to many? Think of apartment complexes and mobile home parks.  In our case, the Parcel IDs were supposed to be unique, not recycled and specific to a single parcel polygon; however in some cases there were multipolygons that shared an ID - it was a single record but graphically showed multiple polygons, each with the same Parcel ID.
As long as your methodology for data clean up after your join is thorough, you should be fine.
Since you are at your beginning stages, another workflow process to consider might be ESRI's Address Data Management solutions; https://solutions.arcgis.com/local-government/help/address-management/
You might want to also consider a multipoint feature.  So, this would be an environment where you would have a graphic point to represent the driveway entrance, another point for centroid of the structure and another one for the main entrance to the structure and one for the side entrance to the structure and one for the unattached garage; but would be a single record in your table.  While this workflow sounds intense, it may make sense for a base for your feature as you work through issues in years to come.
