Accuracy Domain for Plans
2211
03-27-2014 03:33 AM
JeffWard
Honored Contributor
I am hoping this has happened to someone else and they can help me out.
When I create a plan in the plan directory and try to select the accuracy, I have an empty drop down and I am unable to enter a number manually.  I checked the domain in the file geodatabase under the Accuracy field in the ParcelFabric_Plans table and it says it is using the lrAccuracy domain, but there are no choices when I create or change the properties of a plan.  I can add the table to the map, open the table and the domain works in the field, but still doesn't show up in the plan directory properties for the plan.
What am I missing?
Thanks in advance.
Jeff Ward
Summit County, Utah
RyanKelso
I ran into this a couple of weeks ago.  I think you need to edit your parcel fabric's accuracy table, which I'm guessing is currently empty.  In an edit session, run the Make Parcel Fabric Table View tool in the Parcel Fabric Tools toolbox > Layers and Table Views toolset.  In the tool's dialog, change "Select Parcel Fabric Table" to Accuracy.  Then you have a table to open and add accuracy categories to.
I opened the tax parcel editing map template with the Bloomfield Township, MI sample data and just copied the values from that database's accuracy table.
Viewing and editing the parcel fabric Accuracy table
About accuracy in the parcel fabric
-Ryan
