save mxd, pathes not saved
2931
01-29-2018 03:54 AM
ThorstenBrune1
try to save mxd, relative pathes are set. When i reopen mxd the pathes are not saved (look at video)
What is the reason? Can I change preferences? is it a Bug?
DanPatterson_Retired
can't watch video, relative paths means
  • that your data are in the same folder as the the mxd or  ie c:\your_path\your.mxd
  • in a folder within that folder... ie c:\your_path\yourdata\my.gdb
  • If your data are elsewhere, then the paths are not relative ie c:\yourdata\my.gdb
ThorstenBrune1
(view in My Videos)
I have load the video as mp3 data.Can you see it?
I know the meaning of relative pathes, but problem is, that the data source is not here even if I save the mxd. Pathes are the same.
Apparently it is 'encoding'
perhaps, you could write down the paths in a similar fashion to my example to expedite matters.
And to confirm... saving with relative paths, does nothing with the data if just the mxd is moved... everything has to be moved at the same time.
XanderBakker
Esri Esteemed Contributor
Are you storing the MXD on the same drive as where the data resided?
Only paths on the same disk are converted
Relative paths cannot span disk drives. That is, if the root directory is on drive D, you cannot use relative paths to navigate to a directory on drive E. When you store your map document using relative paths, only those paths that are on the same drive are converted and stored.
See: Paths explained: Absolute, relative, UNC, and URL—Help | ArcGIS Desktop
ThorstenBrune1
path is easy. mxd is in GIS-FOLDER. Geo Database is in the same folder. Drive is the same, nothing changes in folders for nearly a year. We dont copy mxd or geodatabase.
