Can an Esri Geodatabase appended to a geodatabase in an enterprise SQL SDE environment?
598
07-19-2017 02:17 PM
CesarSimon
I want to add a Esri personal or file geodatabase into a existing geodatabase which is an enterprise SQL SDE environment. Is this possible?
Greg_Mattis
It is possible using the append tool or the Import from Geodatabase (Single) or Geodatabase (Multiple) but you would need Desktop Standard or Advanced in order to edit or create feature classes within the SDE geodatabase.
Greg Mattis, GISP
GIS Analyst
City of Visalia
Robert_LeClair
Esri Notable Contributor
There are many ways to migrate data from single user (i.e. file geodatabase) to a multiuser geodatabase.  Please see the following help topic for several ideas.
