To weight one attribute higher for Grouping Analysis?
4533
05-12-2015 01:36 AM
IsabellRuehl
Hello,
is there a possibility to weight some attributes higher than others?
So that the Grouping Analysis tool use first the highest weighted attribute to group the polygons and then the other ones.
Thank you all!
JayantaPoddar
Hi Isabell,
You could add a new field "Weight" and define values on a scale of 5/10 or whatever value suits you.
Think Location
IsabellRuehl
Hi Jayanta,
thanks for your help, but i don´t understand how does the tool knows that it should use this "weight attribute" as highest and not one of the other five attributes, which i use for my analysis?
