The new Optimized Hot Spots Tool in ArcGIS 10.2
3442
08-06-2013 12:40 AM
origudes
Hi Lads
I have noticed that while using the Optimized Hot Spots Tool in ArcGIS 10.2, always when i am trying to use the method that produce fishnet / grid cell, it always turn to be in "disabled mode"  did i miss anything? does the field needs to be in a particular type? for example only integer / double etc?
Regards Ori
SedaKahraman1
Hi Lads
Regards Ori
Hi gudeso,
This is because of the Analysis Field. When you define anything to this parameter, you can't use other options. When you define a field, it calculates like hot spot analysis but you don't decide any parameters.
Then if you won't define anything, it calculates only spatial dispersion with fishnet polysons,aggregation polygons etc...
