Spatial Join Trouble
1274
05-02-2013 01:30 PM
dylancummings
Hey Guys,
I am trying to join three different layers. I have one layer of my state (Florida), one layer that i created from the Florida layer where i used the dissolve tool to break the state up into several regions, and then i have an excel file that i am working with that has population data. What i need to know is how many regions have a population greater than xyz and a population density of xyz...Now, to do this i joined my spreadsheet of population data to the Florida layer. Then, i took my dissolved layer and put it on top of the Florida/Spreadsheet joined layer. My idea was that if i spatial joined the dissolved layer with the underlying layer it would aggregate the data and tell me the population (since its by county) of all the counties that make up say Region 1 so i can then tell how many people there are in Region 1....well when i added up the population from my spreadsheet of the counties in Region 1 i get like 490,000 people but when i spatial join it says that the population for Region 1 is like 800 something thousand. I have used the quick right-click join you can do in the TOC and i also used the Spatial Join tool in the toolbox and they both yield the same results. Can anybody help because i can't figure it out to save my life right now...
KristinAldous
It sounds like this might be a problem in how the spatial relationship between the county and regions is defined - counties that are on the border of regions may be being selected and causing the overcounting.
If you are using the Spatial Join tool, you are given a choice on how to define what should be joined (e.g. intersects, contains, is within a distance of).  I believe the 'right-click' from TOC spatial join just uses intersect as default.  You might want to take a look at which counties are select using 'completely contain' option.  I sometimes run the 'select by spatial location' to check out what would be joined with each option as sometimes it is hard to conceptualize.
Hope that this helps.
Kristin
KristinAldous
You may also select spatial join with the right-click TOC join.  It is a drop-down.
