space time cube memory error
2007
10-28-2016 11:54 AM
LizGoldman1
Hi All,
I'm running into an error for the Create Space Time Cube tool. It says "File 'C:\Program Files (x86)|ArcGIS\Desktop10.5\ArcToolBox\Scripts\SSDataObject.py", line 535, in obtainDataGA self.master2Order[masterID] = row MemoryError."
My point file is quite large - 23.3 million records and over 2gb, it is stored in a file geodatabase. Any ideas on how to get around this? I'm using the prerelease of v10.5.
DanPatterson_Retired
unless they switched the version of python and made 10.5 64 bit, you are still limited to memory use.
See the Pro documentation that indicates that there were some changes in Pro 1.3 and arcmap 10.5
Create Space Time Cube—ArcGIS Help | ArcGIS for Desktop
I would try it in Pro as well to overcome memory issues
LizGoldman1
Hi Dan - thank you so much! Using Pro solved my issue.
