Problems withs Morans spatial autocorrelation tool
5340
02-26-2016 09:27 AM
CamiloArias
Hello every one:
I´m trying to run the Moran's I spatial autocorrelation tool but there is an error:
updateParameters Syntax Error: Runtime error Traceback (most recent call last): File "c:\program files (x86)\arcgis\desktop10.2\ArcToolbox\Toolboxes\Spatial Statistics Tools.tbx#SpatialAutocorrelation_stats.UpdateParameters.py", line 2, in File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy__init__.py", line 24, in from arcpy.toolbox import * File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\toolbox.py", line 356, in from management import Graph, GraphTemplate File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\management.py", line 22, in import _management File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy_management.py", line 14, in import _graph File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy_graph.py", line 27, in import numpy File "C:\Users\Cris Arias\AppData\Roaming\Python\Python27\site-packages\numpy__init__.py", line 170, in from . import add_newdocs File "C:\Users\Cris Arias\AppData\Roaming\Python\Python27\site-packages\numpy\add_newdocs.py", line 13, in from numpy.lib import add_newdoc File "C:\Users\Cris Arias\AppData\Roaming\Python\Python27\site-packages\numpy\lib__init__.py", line 8, in from .type_check import * File "C:\Users\Cris Arias\AppData\Roaming\Python\Python27\site-packages\numpy\lib\type_check.py", line 11, in import numpy.core.numeric as _nx File "C:\Users\Cris Arias\AppData\Roaming\Python\Python27\site-packages\numpy\core\numeric.py", line 7, in from . import multiarray ImportError: DLL load failed: %1 no es una aplicación Win32 válida
I looked for answers but there is no answer and I really need your help.
Thanks for get the time to help me
DanPatterson_Retired
from a python window type
import numpy
does it work?
