Pearson correlation in raster datasets
11395
11
09-27-2010 07:51 AM
AlanFernandes
Dear all,
I need to make a correlation between two raster datasets. I want to use Raster Calculator, but I'm still finding a bit difficult to work it out. I have the formula from statistics books, and I know that I'm required to multiply, and add the grids, right? But it's not so straight forward.
How am I supposed to find N, for instance? Should I just multiply the Columns and Rows from my grid to see how many pixels I have on the dataset?
The formula for the Pearson correlation coefficient is quite long and I don't think I should attempt to do everything in one go. I reckon I should do it by different stages.
Any ideas would be very welcome!
Just a couple more things about the two datasets: one of them is a NDVI that I acquired from LANDSAT 5TM, and the other raster has been originated from an interpolation of points (rainfall gauges). I have used Mask on both grids, therefore they have the same number or rows and columns (same number of pixels?).
Thanks for your time.
Alan.
JessicaBerryman
What is the difference between using the above procedure and using band statistics to calculate the correlation between rasters?  I am hoping to find the correlations between my environmental variables prior to further analysis in maxent.  Any thoughts would be greatly appreciated.
         Jessica
SarahPene
Like Jessica I am also trying to find which of my environmental layers are highly correlated before using them in Maxent. The correlation matrix that it produces has many values outside of the -1 to 1 range, can anyone tell me what the problem is there?  (I'm using the worldclim 1-19 layers, 30arc seconds, clipped to Europe).
