Nearest Neighbor Error 999998 - failed to execute
698
05-01-2013 06:55 PM
MegThibodeau
I'm running a nearest neighbor analysis on a shapefile and it keeps failing instantly and the message is "error 999998: unexpected error" and failed to execute.
I used nearest neighbor previously and had the same problem. I know I changed something to fix it but I can't figure out what. The map I previously used it on still works on the same computer, but even if I load the new shapefile into that map, it doesn't work.
Any suggestions?
