Hello, I am going to perform Spatial Analysis with GWR. Regarding with data, I cannot use Binary Variables (0,1) in GWR. For this case, how can I use categorical variables such as (CBD,Suburb, Metropolitan) to be usable in GWR? Although my friend say "use
1244
06-28-2020 06:07 AM
by Anonymous User
Not applicable
LynneBuie
Hi Ei Pyone‌,
If you are using ArcGIS Pro 2.3 or later, you can use the Logistic model to run GWR with the binary variable as the dependent variable. The tool supports continuous, binary and count models. This documentation goes into more details about each of the models. You can use categorical variables as the explanatory variables, as long as you encode these.
Depending on your problem, you might also be able to use the Forest-Based Classification and Regression tool.
Regards,
Lynne
