Forest based and boosted classification and regression - tool errors
2134
07-23-2024 03:42 PM
vsuresh
Hi, I'm running a random forest classification using the Spatial Statistics Tool "Forest Based and Boosted Classification and Regression." I have three explanatory 30m rasters (canopy height, canopy layers, large tree density), all of which are numeric.
Prediction Type: Predict to raster
Model Type: Forest-based
Input training features: a point feature class with a field that indicates presence and absence (True/False, so I am treating the variable as categorical) of mature forest across the area of interest.
The tool seems to nearly finish running, but fails with the following errors. Has anyone seen the same errors before or know what they indicate?
File "c:\program files\arcgis\pro\Resources\ArcToolbox\scripts\SSForest.py", line 8124, in <module>
#### Projection Group ####
File "c:\program files\arcgis\pro\Resources\ArcToolbox\scripts\SSForest.py", line 7556, in execute
self.yMax = self.intersection[3]
File "c:\program files\arcgis\pro\Resources\ArcToolbox\scripts\SSForest.py", line 7455, in rasterWorkFlow
def getWorkExtent(self):
File "c:\program files\arcgis\pro\Resources\ArcToolbox\scripts\SSForest.py", line 5658, in executeModel
return None
File "c:\program files\arcgis\pro\Resources\ArcToolbox\scripts\SSForest.py", line 5520, in processRasterByParts
outputStats = outputStats.reshape((len(indices), numIterationRobust))
AttributeError: 'NoneType' object has no attribute 'shape'
Failed script Forest-based and Boosted Classification and Regression...
Failed to execute (Forest).
DanPatterson
MVP Esteemed Contributor
look at
BUG-000167899 for ArcGIS Pro (esri.com)
but it won't be coming real soon and you may not want to downgrade
... sort of retired...
DanPatterson
look at
vsuresh
Ah, I see. Thank you for the quick response, Dan!
I just updated and downgrading will be a whole IT thing... so may just have to try a different approach.
