Does anyone generate schematic diagram by custom query from schematics service?
3555
05-09-2013 07:21 PM
Yu_ChingYu
As title.
I want to generate a diagram from Schematics Services on ArcGIS for Server 10.1 SP1.
Followed the schematic tutorial and created a custom query schematic diagram template.
We can use this template for generating a diagram on ArcGIS for Desktop.
[ATTACH=CONFIG]24189[/ATTACH]
After tested, we published this diagram as schematic services.
Open the services rest page and try to generate a diagram from the template.
[ATTACH=CONFIG]24190[/ATTACH]
The response is:
[ATTACH=CONFIG]24191[/ATTACH]
Please help!!
Thank you!!
by Anonymous User
Not applicable
Original User: 4233
Lots of missing details in the question that need answered to better help.
*  Does the diagram already exist?  If so, then just like on the desktop, you will get an error message because the name is a unique identifier.  You need to check to verify the diagram doesn't already exist.  If it does, just open the existing and let the user update it if needed.
*  When you published the map, did you publish the diagram template or just the diagram?  For the SOE to allow generation, you must publish the diagram template.
*  Did you enable editing in the SOE options during publishing?
*  Is the diagram and template in SDE?  If not, you won't be able to generate, just a limitation if using fgdb.
These 2 resources have lots of information about publishing diagrams:
http://resources.arcgis.com/en/help/main/10.1/index.html#//015400000464000000
http://resources.arcgis.com/en/help/main/10.1/index.html#/Authoring_schematic_layers/015400000312000...
