Creating a bar graph in ArcMap
3263
07-11-2012 11:37 AM
KimballHansen
I would like to graph my data from a shapefile. The data I wish to display is the sum of the nominal data per each year that it occurred.
I have enclosed a screen shot of what I mean. In red, is the column of data I wish to graph. I want the W's totaled per year and the A's totaled per year. Then I can display those bars on a yearly basis with their respective totals. If that makes sense, please help me. Thank you.
[ATTACH=CONFIG]15970[/ATTACH]
SolomonPulapkura
Use ArcToolbox > Analysis Tools > Statistics > Summary Statistics
Statistis Field will be the field you want to SUM. Choose SUM for Statistic Type
Case Fields will be Year field and SIG field.
Once your table is created you can create the Graph the way you need it.
Hope this helps.
