Using Global Moran's I and the distance units do not match dataset. Any ideas how I sync the dataset to report outcome?
1404
01-21-2018 08:02 AM
JeffChartrand
Hi I am using spatial autocorrelation (Moran's I) with the ESRI training set but when I try and run it on the California Ozone dataset (in feet and displays at bottom of page) the report give me the correct value in feet but lists the units as Meters on the report.  I can not seem to find how to change the output value to match the units of the dataset.  Any help appreciated.
DanPatterson_Retired
by chance are the datasource units in meters?
JeffChartrand
Hi, apparently, in my adding of data the Layer thought it was in feet so even though I checked the subsets which were in metres the display kept saying the measures were in feet.  So your message worked.... Problem solved.  Thanks!!!
Marked as 'Assumed Answered' then Jeff
