TimeControl to playback historical data on temporallayer
1607
10-16-2016 02:03 AM
JhonChin1
/// <summary>
/// Open a timecontrol and control a playback sequence without displaying the timecontrol GUI.
/// </summary>
/// <param name="application">An IApplication interface.</param>
/// <remarks></remarks>
public void TimeControlPlayback()
ESRI.ArcGIS.Carto.IMap map = axMapControl1.ActiveView.FocusMap;
ESRI.ArcGIS.Carto.IMapTimeDisplay timeMap = map as IMapTimeDisplay;
ESRI.ArcGIS.TrackingAnalyst.ITemporalLayer temporalLayer = null;
if (map.get_Layer(0) is ESRI.ArcGIS.TrackingAnalyst.ITemporalLayer)
temporalLayer = (ESRI.ArcGIS.TrackingAnalyst.ITemporalLayer)map.get_Layer(0); // Explicit Cast
if (temporalLayer == null)
timeMap.ShowTime = true;
return;
Type factoryType = Type.GetTypeFromProgID("esriTrackingAnalystUI.TimeControl");
ESRI.ArcGIS.TrackingAnalyst.ITimeControl timeControl = (ITimeControl)Activator.CreateInstance(factoryType);
System.Int32 int32_hWnd = axMapControl1.hWnd;
timeControl.CurrentMap = axMapControl1.ActiveView.FocusMap;
timeControl.SetTemporalReferencesFromMap();
timeControl.TemporalMode = ESRI.ArcGIS.TrackingAnalyst.enumPlaybackTemporalMode.enumTemporalHistoric;
if (!(timeControl.Status == ESRI.ArcGIS.TrackingAnalyst.enumTimeControlStatus.enumStopped)&&timeControl.Status<enumTimeControlStatus.enumInValidView)
timeControl.Stop();
timeControl.SetTimeSequenceInterval(ESRI.ArcGIS.TrackingAnalyst.enumTemporalUnits.enumDays, 1);
timeControl.CurrentTime = timeControl.StartTime;
timeControl.UpdateDisplay = true;
timeControl.WindowTitle = "test";
try
timeControl.Play(ESRI.ArcGIS.TrackingAnalyst.enumDirection.enumForward);
catch (COMException ex)
System.Windows.Forms.MessageBox.Show(ex.StackTrace);
everything is ok until Play, report an error like this:
System.Runtime.InteropServices.COMException (0x80040980): The Time control must be activated before it can be made visible.
