Raster to Polygon conversion - showing error
2269
02-05-2014 08:49 PM
VikasRanga
Hi all,
To convert from Raster to Polygon, I am using "Toolbox --> Conversion tools --> From Raster --> Raster to Polygon". Input image (Image.JPG) is also attached with this post. Following error is showing, snapshot (Error.JPG) is also attached:
  • ExecuteError: ERROR 010328: Syntax error at or near symbol SPACE.
  • ERROR 010267: Syntax error in parsing grid expression.
Waiting for solutions. Need urgent.
Regards
Vikas
RachelApplebaum
Hi Vikas,
Do you have any special characters, such a parentheses or dashes, or spaces in the input or input file paths and names? Also check for special characters and spaces in the field names. Those could also be causing issues. If so, remove them and try running the analysis again.
Hope this helps!
-Rachel
