Populate field with value from underlaying polygon layer
3789
11-13-2014 05:14 AM
RobertThomson
I have two separate layers, property records and water meters.  I would like to populate a field in "water meters" with the value of a PID (Property Identification) field found in the property records layer for which it touches.
Is this possible?  Hope I have the right group.
RobertThomson
The answer is to use the Geoprocessing Tool Spatial Join, answer from ESRI Tech Support.
This tool can be found in ArcToolbox> Analysis Toolbox> Overlay toolset> Spatial Join. Here is some information about how the Spatial Join tool works:
Spatial Join -
http://resources.arcgis.com/en/help/main/10.2/#/Spatial_Join/00080000000q000000/
Select By Location: graphic examples -
http://resources.arcgis.com/en/help/main/10.2/index.html#//0017000000tp000000
RobertThomson
Spatial Join -
