Multiple Ring Buffer displays 2.5 Km polyline  within 30 metres ring?
7356
12
07-29-2014 10:56 PM
SebastianSalazar
Hello folks.
In Arc Map 10.1 I have I polyline with distances (2.659542 m) and length (0.00266 km) fields. Those fields were calculated with geomtric calculator.
I am tryin a Multiple Ring Buffer Tool with 30, 50 and 100 metres of distance. At the end, the tool shows 3 rings, however,
2.5 Km polyline is located within the 30 metres ring (see littel blue polyline in inner ring). I am really confused. Why 30 metres ring is larger than polyline length?
The polyline is in WGS 1984 World Mercator.
Can you give an idea(s) to fix this problem?
SebastianSalazar
Melita. Now the MRB is working as expected.
Thank you very much indeed.
IanMurray
Honored Contributor
Sebastian Salazar wrote:
Hello folks.
I think you may have answered your own question.  Accoding to your original post, you line is only 2.659m,  not kilometers(or as you mentioned .00266km).  I'm assuming you are only working with a single line, not multiple lines anytime you buffer a feature, the resulting buffer by definition should contain your input feature(unless you are using a negative value buffer).  So yes, your 2.659m polyline should be within your 30m radius buffer.
SebastianSalazar
Ian.
Using the recommended process from Melinda, now the MRB is working.
Many thanks for your reply.
Cheer's
