Least cost path
3436
06-20-2014 10:16 PM
gunajitsarma
I have been trying calculate least cost path using this model. But from the cost distance block it keeps on running but provide no results. Is it due to so kind of data error? Because logically it is very simple.[ATTACH=CONFIG]34785[/ATTACH]
[ATTACH=CONFIG]34786[/ATTACH] The process just gets stuck there.
Please give a solution.
by Anonymous User
Not applicable
Original User: Gunajit
Please give suggestions
MarkBoucher
Honored Contributor
Geoprocessing over a network can cause errors for some reason. Try putting a copy of your destination.shp data on your C: drive an see if that doesn't fix it. Also, working with geodatabases instead of shape files is more stable, so if the first suggestion doesn't work, try putting the data in a geodatabase.
