Is there any way to restore my default 'geoprocessing environment' settings?
7145
6
05-01-2016 11:48 PM
NasirHameed
I am intending to restore my default 'geoprocessing>environment' settings automatically, how would I do this?
Tags (1)
curtvprice
Unfortunately, applying these tools in the Python window apply there and do not necessarily propagate to the entire ArcMap session. I've always found this frustrating. Starting a new map document is the only "automated" way I know how to do this. Perhaps a Python add-in would do the trick, but I have not tried this.
JayantaPoddar
Resetting Environment using ArcPy
The ResetEnvironments function can be used to restore the default environment values, or the ClearEnvironmentfunction can be used to reset a specific environment.
import arcpy
# Reset geoprocessing environment settings
arcpy.ResetEnvironments()
# Reset a specific environment setting
arcpy.ClearEnvironment("workspace")
Using environment settings in Python—Geoprocessing and Python | ArcGIS for Desktop
Think Location
NasirHameed
Jayanta Poddar​ Thank you for the help, I had paste this function in Python Window and rechecked my Environment settings, it didn't seems to be working.
JayantaPoddar
I have attached a python script.
Right-click the file > Edit with IDLE
Run > Run Module (F5)
Think Location
curtvprice
AbdullahAnter
Honored Contributor
Open a New MXD (New Map Document).
the environment' settings restore automatically in new mxd.
you can copy your layers and paste it in new mxd.
NasirHameed
Jayanta Poddar​, I have strictly followed the instructions to execute the expression you have provided but It didn't changed the settings automatically. I am not sure what went wrong. I am using ArcGIS 10.3 installed on C:\Program Files (x86)\ArcGIS. However, I am thankful for the anticipation and your time.
