How to start in GIS without previous knowledge and a defined problem?
3742
03-09-2016 02:40 PM
HayleyHaydon
Hello there!
I'm absolute new in GIS and hope I'm right, coming here from wrtiting my thesis in environmental engineering. Therefore I need to calculate some values from a database (buildings in a part of a european city) available in QGIS in a grid of one km² per cell to get in the end the roughness of this part of the city.I assume, this is a standard operation in GIS (how many ... per km² are ... ), but I really have no idea how to start, and the company I work for isn't helping me.
So I would be very gratefull for some hints about what I need for solving this task. Like some important terms, etc. - I know that GIS is a complex science and I also want to engage, but first this is a concrete problem I need to solve quickly, so I don't have so much time to start a fulltime tutorial in QGIS.
I hope, there is someone who can help me with this!
DarrenWiens2
You should ask this question on a more general GIS forum, like: Geographic Information Systems Stack Exchange
...as this forum is specifically for ESRI ArcGIS software (similar, but different to QGIS) users.
MelitaKennedy
Esri Notable Contributor
A few hints, although I don't do much analysis.
1. What coordinate system is the building dataset using? You'll want it to be in a projected coordinate system (PCS or ProjCRS), localized as much as possible for the city. You might be able to use http://www.epsg-registry.org to get some ideas (likely none available for the city, but the country might have several zones. Note: the ProjCRS will likely be using meters for the units which leads into question 2.
2. Do you have the square kilometer grid yet? If not see if QGIS has a "fishnet" or grid tool to make a polygon-based dataset. ArcGIS does: Create Fishnet. Make it in meters so that it matches the ProjCRS from (1).
3. Then you can intersect or do some statistical analysis--I'm not sure of the correct terms here. You may also have to think about whether buildings that in two or more "cells" of the grid should be counted.
I hope this helps you to get started at least.
Melita
DarrenWiens2
Okay, if an ESRI employee is going to promote a QGIS answer then so will I.
The QGIS equivalent to ArcGIS fishnet is Create > Create Grid Layer within the MMQGIS plugin. It's a pretty cool tool that can also make a hexagon grid for you.
MelitaKennedy
I've been a student struggling with software and a new field...!  gis.SE can be a bit of a scrum too.
