How to find the maximum rectangle contained within a polygon
28687
10
08-25-2016 04:03 PM
by Anonymous User
Not applicable
Hi.
There is are arcmap tools that can return a bounding box/rectangle/envelope etc for a given feature (e.g. set of points, line or polygon). I am trying to find a similar tool that will return the maximum rectangle that can be created that is *contained within* the features.
Here is a link to the Arcmap/Pro tool:
Minimum Bounding Geometry—Data Management toolbox | ArcGIS for Desktop
Here is a link to someone else's StackExchange question that explains fairly well with diagrams what I am trying to achieve:
geometry - How to find the maximum-area-rectangle inside a convex polygon? - Geographic Information ...
Would be interested to know if anyone has already solved this using existing Arcmap tools without delving into complicated scripts...?
Cheers
-Paul
BenjaminPezzillo
FLOATING RECTANGLE
Any solution(s) to generate the largest 'floating' rectangle -- i.e. a shape that does not have a point(s) on the polygon?
