Directionality issues
2916
10
06-26-2019 04:31 AM
GeorgiosKapou
Hi all,
I have a shp with cycling routes and I would like to draw out directionality's data.
I realise that through the network analyst tool I can get some directionality information but it works for the "new Route" analysis layer and I can not use it for my shp.
Do you know how could I get this information in a different way?
I appreciate any suggestions.
Thank you in advance,
George
RobertBorchert
Honored Contributor
I am not certain what an Antennas directional sensitivity would have to do with it.
The issue your most likely having is your getting mixed around by the digitized direction.  i.e. the direction the line was originally drawn.  You can use the Flip to change digitized direction.
GeorgiosKapou
Hi Robert,
thank you for your answer.
I want the draw out information about the routes directionality e.g. north, south, west..., for the whole route or for the every segment of the route.
Do you have any suggestion for me?
George
RobertBorchert
Honored Contributor
I believe you will simply have to go to each route and set the digitized direction to the direction you want.
Make your line symbol to be Arrow at End (preset symbol) and you can easily see which end is which.
The you can right click on a line and select flip or select multiple lines and use the FLIP LINE tool to quickly flip one or multiple lines.
suggestion, Create a custom toolbar and put common tools in there and have it floating. Or as I like to do create a hot key command for a specific tool.
GeorgiosKapou
As I understood with the flip tool I can change the direction of a line. Please correct me if I am wrong.
I want directionality information (e.g. north, south etc. ) from a shp to draw out e.g. on an excel file, for the whole line or for any segment of the line.
Actually, with the Network Analyst tool I can have some of this information but it only possible from the analysis tool layer and not for the shp.
Please see attached.
RobertBorchert
Honored Contributor
So then put the shape file in a database
GeorgiosKapou
Do you know what steps I have to follow since I am confused about how I can do it?
Thank you!
RobertBorchert
Honored Contributor
Start ArcCatalog create a new database, create a new dataset with the appropriate projection, import the shape file.
GeorgiosKapou
OK. Thank you. When I create the database how will I get the directionality data?
RobertBorchert
Honored Contributor
The say way you got it with your attachment.
