Converting a raster to a polygon
3815
01-30-2014 01:34 PM
by Anonymous User
Not applicable
Original User: Schack
I need to convert a raster into a polygon, and I ran into "Error 000863:  Invalid GP Data Type"
After searching, I saw this solution online.
Basically I needed to convert the float raster to an integer raster.  I used the times tool to multiply my raster by 1,000,000.0 to preserve all the decimal places.  When I compare the resulting raster, it seems Arcgis has rounded the value for each pixel up by one (See the pixel values in the images below). I was hoping to preserve these exact values.  Is there another approach I can try?
[ATTACH=CONFIG]31001[/ATTACH]
[ATTACH=CONFIG]31002[/ATTACH]
by Anonymous User
Not applicable
Original User: xander_bakker
Hi Aaron,
Sorry, but I have to ask; can you justify based on your data precision to be bothered by such a small difference (0.000001 is 0.00000464%)?
If so, what you could do is to determine the center point for the polygons (calculate geometry), convert these coords to a point featureclass, use the extract values by points on the original raster (before multiplying), join the result back to the polygons and overwrite the values.
Kind regards,
Xander
