Add raster values under points to table
2451
06-10-2017 06:26 AM
MichL
I have some points overlayed on top of a raster. Is there a tool in ArcGIS Desktop to add the values of the raster that the points fall on top of into the point attribute table?
XanderBakker
Esri Esteemed Contributor
The tool part is part of Spatial Analyst and is called Extract Values to Points—Help | ArcGIS Desktop . If you have multiple rasters you should use the tool Extract Multi Values to Points—Help | ArcGIS Desktop
XanderBakker
curtvprice
There's another tool (much older -- dates back to ArcInfo GRID in the mid 1990s!)  which is helpful in certain workflows because it is more integrated with the raster geoprocessing environment. I have sometimes had to use it when the other two tools fail.
Sample—Help | ArcGIS Desktop
