Displaying data (Voxel Layer)
2941
01-12-2021 11:13 PM
Kristiewwm
We got some raw data which would be converted into netcdf format, and visualised by using voxel layer. We are exploring methods on making boreholes so that the voxel layer would be like a underground pipe in ArcGIS Pro.
Is there any suggestion or example similar to this case?
Thanks a lot!
VictoriaPhillips1
Esri Alum
Hi, @Kristiewwm I am not 100% sure how to convert the data into a voxel layer however @Anonymous User might know. You can also look at this recent post Three ways to prepare your data for Voxel Layer
Hope this helps or gets you closer to solving this!
Best,
Victoria
by Anonymous User
Not applicable
Thanks @VictoriaPhillips1
@Kristiewwm Your use case is definitely possible. What sort of a raw data is it? I would recommend following through this blog -
https://www.esri.com/arcgis-blog/products/arcgis-pro/3d-gis/raw-data-to-netcdf-voxel-layer/
Let me know if this works.
Kristiewwm
Thank you @VictoriaPhillips1  and @Anonymous User !!
We are still figuring it out with the support of the reference post and blog.
We only have X/Y coordinates and length details in raw data, possibly in CSV format.
We will try it first, thanks!!
