Hide a WebMap from Collector for ArcGIS
1591
08-27-2018 06:53 AM
EricRodenberg
(view in My Videos)
Sometimes you have WebMaps you don't want Collector for ArcGIS to see.  Here is a simple workflow to hide WebMaps from Collector for ArcGIS so they don't show up in your list of available editable WebMaps.
  • Go to ArcGIS Online Assistant and sign in
  • Click on the I want to... drop-down on the top bar and select View an Item's JSON
  • Use the list of folders down the left-hand side to find the map you want to hide from Collector
  • When you select your map, JSON from the WebMap description should display in the main panel
  • Click the Edit pencil, in the upper right of the WebMap description and find the line in the "typeKeywords" section near the top that says "Collector," and delete it
  • Save.#
Eric J. Rodenberg | Solution Engineer Transportation Practice
Esri | 7775 Walton Pkwy, Suite 270 | New Albany, Ohio 43054-8202 | USA
T 614-933-8698, ext. 5503 | [email protected] | esri.com
