Running a Select by Attribute Query in RCE returns a 404 error
2183
05-18-2021 11:41 AM
SamuelColdiron
Hello RHUG,
We recently starting running into an issue where running a Select by Attribute Query in RCE will sometimes return a Status: 404 error. We have tried clearing cache and changing browsers, but we can't find a common theme that will trigger it or keep it from happening.
Has anyone run into this? Is there a query size limit in RCE? Thoughts?
Thank you for the help in advance,
Sam Coldiron and the Oklahoma DOT LRS Editing Team
Tags (3)
RyanKoschatzky
Sorry the business unit issue was a different query issue in EE not a 404 error.
bbieb
I do not remember the exact error we had but we ran into query length issues and had to modify the web.config on the web adaptor RCE was hitting.
https://support.esri.com/en/technical-article/000015245
brian
<system.web>
    <!-- 8/12/20 bb https://support.esri.com/en/technical-article/000015245 -->
    <httpRuntime maxRequestLength="2097151" maxQueryStringLength="2097151" maxUrlLength="2097151" executionTimeout="100000" targetFramework="4.5" />
    <!-- <httpRuntime maxUrlLength="2000" maxRequestLength="2097151" executionTimeout="100000" targetFramework="4.5" /> -->
</system.web>
<system.webServer>
    <security>
         <requestFiltering>
	    <!-- 8/12/20 https://support.esri.com/en/technical-article/000015245 -->
            <requestLimits maxUrl="2097151" maxQueryString="2097151" maxAllowedContentLength="2147483648" />
            <!-- <requestLimits maxAllowedContentLength="2147483648" /> -->
         </requestFiltering>
     </security>
</system.webServer>
brian
