RH_User_Group_January_2019.pdf
415
01-09-2019 12:39 PM
Recorded meeting https://meetny.webex.com/meetny/lsr.php?RCID=43d7316998b347aca90510368ddf29bb
Meeting chat view transcript:
from Adrien Litton to everyone:
What happens when I post a version up without applying event behaviors?
from Nicole Hanson to everyone:
Will you still have to run "update intersections" before applying event behaviors
from Matt Ziebarth -Esri to everyone:
This is Matt from Esri - to the question about importing and copying maps between Pro projects, in addition to sharing a service or web map with your organization online, yes you can do that and yes it is a simple matter of copy and paste. You can also import maps from ArcMap mxds. You can read more here: http://pro.arcgis.com/en/pro-app/help/projects/add-maps-to-a-project.htm
from WV DOT to everyone:
are you doing yor edits in a version?
from brian_bieber_nddot to everyone:
Is using a feature service a requirement in Pro?
wow, that is a big change!
yes
we have a lot of routes
from Anthony Popp (Esri) to everyone:
Geodatabase Compress
from Steve H. - Maricopa County to everyone:
Post, Reconcile, Compress, Analyze and Rebuild Indexes helps us at Maricopa DOT
On a regular basis
we do it nightly
from Kyle G to everyone:
Steve H - x2
from Dave DiNocco - MassDOT to everyone:
MassDOT runs Reconcile, Compress, Analyze and Rebuild Indexes as well on a nightly basis. This has worked for us.
Very important in a versioned Geodatabase to run compresses and rebuilding indexes quite regularly.
from Jeromy Barnes - ALDOT to everyone:
ALDOT Compresses and rebuild index weekly
Seems to help us alot...
+ analyze during peak edit periods
Also delete versions not needed and run tools to check for orphaned versions.
analyze during peak edit periods not at night for best results
Version history
Last update:
‎01-09-2019 12:39 PM
Updated by:
Contributors
