R and ArcGIS Apps
1155
04-17-2024 10:26 AM
Gabrielle
I am brand new to R code and its connection to ArcGIS.  We are looking to update our forecasting tool for freight. The consultant is looking to use R to code the app. This information will feed into an existing Hub site. Is it possible to embed an R-coded app into Hub? Is it possible to build app using ArcGIS online that can have r-code in it?
Thank you in advance for your help.
Tags (3)
JosiahParry
Hi @Gabrielle my apologies for the delay. It is possible to build an application that uses data generated from R inside of it. Depending on what exactly you want to do, we might have a solution!
Can you email us at [email protected] so we can hop on a call and learn a bit more about what you're trying to do!
