"Failed to load notebook" when using custom environment
4941
12
11-21-2022 03:38 AM
A_Schwab
I've set up a cloned custom Python environment in ArcPro 3.0.2 to set up the r-arcgisbridge package.
Cloning the environment and installing the package work ok, but when opening a notebook, I get an error, "Failed to load notebook".
If I switch back to the default environment I can load a notebook ok.
Any advice on how to fix this?
HeatherChamberlain
I've been in touch with someone from the ESRI customer care team UK and they advised to clone the environment via the Python command prompt as described here: https://support.esri.com/en/technical-article/000020560, before then installing packages in cloned environment. I haven't tested this extensively but when I tried briefly, this seems to have hopefully solved it for me (I tested with installing rasterio and then geopandas only).
melissaur1039
I have tried that a couple different times and still can't install r-arcgis-essentials unfortunately.
ShaunWalbridge
Yes, that's right, we needed to add a fix on our end to make this work. One of the challenges with conda and custom packages is, once you've released something you effectively can't take it back because it'll be installed and used, and if the dependencies aren't specified tightly, conda will always choose the version that is "easiest" for it to solve, which in this case involved bad dependencies.
We've put the fix up which can be added to any custom environment by installing the `pro-notebook-hotfix` package. There are also details on how to do this in the first question of the Pro Notebooks 3.0 FAQ:
  https://community.esri.com/t5/python-documents/arcgis-notebooks-in-arcgis-pro-3-0-faq/ta-p/1196582
If it is available to you, you can also upgrade to Pro 3.1 which works out of the box without needing to add any additional packages.
Cheers,
Shaun
