Why mouse move is working like mouse pressed and moved ...
1209
04-24-2019 03:34 AM
Girishchandra_Yendargaye
Hello Team,
In QT I used ,
 connect(Toolkit::ToolResourceProvider::instance(), &Toolkit::ToolResourceProvider::mouseMoved, this, &AnyCOntroller::onMouseMoved);
This event is only getting called on mouse pressed and moved..But I want only mouse move..
can you please check.
Tags (1)
JessicaTalbot1
I had to add a MouseArea over the mapView in qml and set the hovered property to true (default is false).
