Problem parsing relative links in KML files
1097
08-09-2021 01:27 PM
KennSebesta
Through a lot of trial and error, I discovered that
<href>./../foo.kml</href>
works but
<href>../foo.kml</href>
 does not.
I finally realized what was going on when I saw the debug output in the Qt Creator console and realized that the plugin was discarding the relative path when it began with `..`. After a little guesswork, I hit upon `./` as workaround.
I saw this on Icon objects, but presumably it's elsewhere as well.
This is using SDK v100.11.2 on macOS.
GuillaumeBelz
Hi Kenn,
Sorry for late answer.
It should work without `./`, depending of the paths. How are you creating the KML file? What is the structure of your files?
Can you provide a file to try to reproduce the issue?
Thank you
