Problem "The program has unexpectedly finished" / "crashed"
7735
5
03-30-2014 11:18 PM
Bryant_JamesLanuza1
hi all,
Help, I'm trying to display map using Qt Creator 5.2.1 base on this link - "https://developers.arcgis.com/qt/guide/displaying-a-map.htm"
but I've got a problem.
see below problem and see attached debug/issues,
Starting C:\Qt\QtWorkspace\build-MyFirstMap-Desktop_Qt_5_2_1_MSVC2012_OpenGL_64bit-Debug\debug\MyFirstMap.exe...
Rendering engine : OpenGL
The program has unexpectedly finished.
C:\Qt\QtWorkspace\build-MyFirstMap-Desktop_Qt_5_2_1_MSVC2012_OpenGL_64bit-Debug\debug\MyFirstMap.exe crashed
Thank and advanced!
JeanneTrieu
Have you authorized the SDK with a valid license?
thanks,
MichaelHeid
I'm also running into the same issue. Looking at this thread, I went to check on my development machine license and it seems that it has expired (the licensing page on my Esri Developer account says it expired on April 8, 2014, but I was able to run a Qt program using the ArcGIS Qt SDK on the 10th), but when I try to renew the license via the Software Authorization Wizard 10.2, it results in
"7174:Only deployed entitlement line item can be fulfilled."
And the authorization fails. Any suggestions on how to renew the license?
Bryant_JamesLanuza1
hi jean,
I'm trying to authorize, but I got an error.
Please see attached.
Thank you,
JeanneTrieu
There is a new license available as of today. You can login to the developers page to get the license string.
Regards,
Bryant_JamesLanuza1
hello,
done well, it's work 🙂
thanks more ,
