Movable labels with a connection line
1322
09-08-2022 12:17 AM
Labels (2)
FatmaAkdemir
Are there any future plans or requests about movable (selected and moved by mouse) labels which are connected to the item with a connector line? Also I want to ask about Qt 6 support for the next releases.
LucasDanzinger
Esri Frequent Contributor
Annotations could be used to click/select/move text around. You'd need to author annotations in ArcGIS Pro and share it as a feature service or in a mobile map package. These basically end up being like editable features that can be moved to static locations on a map https://github.com/Esri/arcgis-runtime-samples-qt/tree/main/ArcGISRuntimeSDKQt_CppSamples/Layers/Dis...
As for leader lines, we have plans to eventually support them with annotations, but don't currently support them.
AlessioWilliamsGava
Regarding you second question, the plan is to support Qt 6 by the end of this year with the new release. You can read more about Qt 6 and 100.15 LTS future support in this blog post
LucasDanzinger
