map.operationalLayers repeating Layer
3104
10
05-15-2019 01:41 PM
MKa
Has anyone ever had an issue with the operational layers repeating a layer when looping through them?  It seems to happen on mobile devices and on appstudio mobile but not on desktop app.
I am simply wanting to loop though the layers, but I seem to have a repeating layer.
 map.operationalLayers.forEach(function(value) {
    popupMessageBox.messageText += "\nvalue.name = " + value.name
In this above example with 4 layers, the first time I run it, it gives me this result
layer.name = 1
layer.name = 2
layer.name = 3
layer.name = 4
Then I run it again and I get this result.  It seems to happen intermittently and only on my mobile device
layer.name = 1
layer.name = 2
layer.name = 2
layer.name = 4
Wondering if anyone has seen this type of behavior?
JamesBallard1
Hi M Ka‌,
I'm not aware of any problems like that. Can you provide some more information, or maybe even a small reproducer app that shows the problem?
You mentioned mobile. Is that Android or iOS? Also, what version of Runtime are you using?
MKa
I can not figure out why this is happening.  It is happening in both IOS and Android and i am running the latest version of Runtime.  I have added 4 layers to my webmap and on mobile (cell) only, it sometimes is repeating the layers when I loop through the operational layers of a given map.
MKa
Is there a way to requery the operationallayers of a map?  It is almost like on mobile, it takes longer to load and somehow a duplicate is getting returned in my above loop.  Again, this only happens on the mobile and it happens using the AppStudio mobile app.
MKa
I am loading a MapView page with a loader, but on mobile when looping through the operational layers I am getting duplicates.  When I return to the page or come into the mapview for the first time.
MapView {
    map: MapFieldSelectedLoader.item
Component.onCompleted: {
        MapFieldSelectedLoader.sourceComponent = MapFieldSelected;
Loader {
    Component {
        Map {
            autoFetchLegendInfos: true
            initUrl: app.webMapUrl
            //This returns the duplicate layer when looping through on mobile
            onLoadStatusChanged:
                    if (loadStatus === Enums.LoadStatusLoaded)
                     operationalLayers.forEach(function(lyr) {
                     popupMessageBox.messageText += "\n Loaded lyr.name = " + lyr.name
JamesBallard1
M Ka‌,
Thanks for the additional info. Is the web map you're accessing public? If so, please share the url and we can try to reproduce the problem on our end.
MKa
Could I get an email in which to send the URL of the WebMap to.  I will need to grant you access and give you a username and password to our portal that holds the web map.  I cannot make the whole thing public.
JamesBallard1
M Ka‌ thanks for the offer. I'll see if I can find a web map with four (or more) layers that we have access to and see if I can reproduce the problem that way.
MKa
That would be so helpful.  You will need to load a mapview/loader/map page again and again, looking at the operational layers on load.  Mine seems to repeat them quite frequently as I mentioned above
JamesBallard1
M Ka‌, one of my colleagues tried this out in a test and wasn't able to reproduce the problem on a mobile device. That was using the same code you provided with a different web map. If you're able, please log the issue with Esri support so we can follow up.
Esri Support Home
