Long delay between physical mouse click and MapQuickView::mouseClicked / SceneQuickView::mouseClicked signals
2154
12-20-2023 03:55 AM
imbachb
Dear esri community
We'd like to use MapQuickView::mouseClicked / SceneQuickView::mouseClicked signals to respond to mouse click events. However, we noticed that there is a considerable delay of about a second between the physical mouse click and the time the mouseClicked signals are emitted / handled. This results in a very unresponsive user experience, for example when the user wants to identify a layer or graphic. These identify operations only take around 50ms, compared to the 1000ms it takes just to receive the mouseClicked event...
Is there anything we can do to decrease this delay?
For testing purposes we set a QML MouseArea over the whole screen. Handling the MouseArea OnClicked event and then identify layers and graphics feels much much quicker than with MapQuickView's mouseClicked signals. But if possible we'd like to keep using the MapQuickView's signals for simplicity's sake.
We're using ArcGIS Maps SDK for Qt Version 200.2
LucasDanzinger
Esri Frequent Contributor
The delay is there so that we can decipher between a single mouse click and a double mouse click. The original intent was that we wanted those signals to be exclusive, meaning you could have one behavior happen on mouse click and another on double click.
One thing you could do if you want a more responsive click experience could be to use the mousePressed and mouseReleased signals. You could run your identify on either one of those, or you could could listen for a press then a release within a tolerance of the same screen coordinate.
LucasDanzinger
TomNorby
Lucas,
Is there currently a way to utilize the Qt values for duration?
qGuiApp->styleHints()->setMouseDoubleClickInterval(300);
qGuiApp->styleHints()->setMousePressAndHoldInterval(400);
If not, would there be value in requesting the ability to match the click behavior of the application?
V/r,
Tom
LucasDanzinger
We currently don't listen to those values for the duration, but I can add an enhancement request to consider respecting those values. I'll need to discuss with the team on the feasibility of this.
