How to pass mapview instance to sceneview
2564
7
12-10-2019 03:20 AM
GirishchandraY
Hello Team,
I am currently using mapview for 2D maps with tiledlayers.
But If I want to switch view to sceneview on click of a button and pass existing layers in mapview to sceneview in CPP widgets.
I don't see any method for the same.
Can anyone suggest something.
Thank you,
Tags (1)
LucasDanzinger
Esri Frequent Contributor
There aren't any convenience APIs available to convert a 2D map to a 3D scene. You'll need to create new layer instances and add those to a new scene.
GirishchandraY
When I tried to create new tiledLayer instance of wgs84 projection on sceneview it is not being displayed...What could be reason for this...because same layer I can see in mapview
LucasDanzinger
SceneView supports Web Mercator by default. If you set the scene view tiling scheme to WGS 84 first, does it work? Scene Class | ArcGIS for Developers
GirishchandraY
How to set tiling scheme to scene as I don't see any option there.
LucasDanzinger
scene->setSceneViewTilingScheme(SceneViewTilingScheme::Geographic);‍
GirishchandraY
Do we have COPY function for sceneview in QT similar to Java
LucasDanzinger
Not yet. That is something we want to add but haven't yet.
